OS: Ubuntu 22.04.1 LTS,Grafana: 9.2.6 - What are you trying to achieve?
Simplifying field overwrite in dashboards - How are you trying to achieve it?
haven’t found a solution
Problem: From influxdb I receive the fields in more “machine”-style syntax - not “human”-readable:
It’s quite “costly” to overwrite every field (about 150 fields in total) in all the panels. Is there a way to define en external mapping once and load it in the dashboard, so the mapping is used to automatically overwriding the fields?
