Adding a Json object not array
Hello I am new to Grafana,
I am trying to use an API I have formatted the API to a JSON, but it is an object instead of an array.
My question is simple, how to I display JSON object data in Grafana. Right now it is saying no data.
I am using the plugin infinity but if you have other way that is fine to.
Kind regards,
Jessy2
Sorry for bad English
Can you provide an example of a JSON response from your API? Something so user’s can try and mock up your data?
{“peer1”:658,“peer2”:582,“peer3”:652,“peer4”:552,“total”:2444}
Hi @jessy2 I tried using JSON server to mock up your data but it complained that this not a valid JSON object. This worked, however, which is not an array but a more clearly defined single object:
  "foo": {
  "peer1":658,
  "peer2":582,
  "peer3":652,
  "peer4":552,
  "total":2444
I would advise tweaking the formatting of your JSON. Is that possible?
Hi @jessy2 have you tried this Grafana
Thank you all for your help I figured it out if I use selectors and set them to string it works thank you all.
