I would like to know if it is possible to add Prometheus as Data source via CLI and not via WEB UI.
I ask this question because I would like to automate the installation and configuration of these 2 tools through an ansible script.
Regards,
Regards,
Yes, it is.
There are two ways to do it that I know of:
https://grafana.com/docs/grafana/latest/administration/provisioning/#datasources
Hope that helps,
Antony.
Thank you Anthony,
I think i will use the second méthode ans if I understand right, i can declare the datasource via cli by editing the etc/grafana/grafana.ini file and add the bloc datasource (URL, user, password) ?
For example:
datasources:
- name: Prometheus
url: http://localhost:$PORT
user: user1
secureJsonData:
password: 123456
Or i have to create this file and declare it in grafana.ini file ?
