Add more than one directory where grafana will look for plugins
Hello Everybody,
how to add in the grafana.ini file at (/etc/grafana/grafana.ini), many directories where grafana will automatically scan and look for plugins.
I could add just one folder, but it is a headache when you are developing many plugins in different folders. I will have to change the config file all the time and restart grafana server.
Please, any advice?
Thank you very much!
Your Sincerely,
Turtles
@companymvms the grafana.ini file only allows a single path, I haven’t tried it, but could you create a symbolic link to your other plugins in that folder?
Hello @melori.arellano,
thank you very much! It worked very well! This is a nice workaround!
Maybe it will help others:
https://www.liquidweb.com/kb/symbolic-link/
Cheers,
Marcelo
