- Lastest version on Docker.
- What are you trying to achieve?
I was asked to provide access to an internal Grafana dashboard using a predefined public URL:
Internal URL: https://grafana.domain.dev/public-dashboard/etcetcetc
Public/External URL: https://dash.publicdomains.com/dashboard
Caveat: I need the URL to remain the external one, since there is no access to the internal Grafana, other than via the proxy.
- How are you trying to achieve it?
I have an internal DMZ HAProxy that does the redirection, but I keep getting the message " 2. If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true."
I’ve set up the required settings but with no results.
I can redirect using the final URL, which is internal, but not using the External.
This is achieved using Grafana or is it an issue with the HAProxy config?
Thanks in advance.
JG
