Hi, I’m looking to use a (key, value) pair in custom template variables. As I understand it, it’s not an option right now. As an alternate solution, I’m trying to understand if there’s a way to access the list of comma-separated values in a custom template variable by index instead? This would work as a good workaround for my use case.
Related topics
| Topic | Replies | Views | Activity | |
| Multi-select template values through pasting list (for example: csv) | 2 | 1117 | June 7, 2017 | |
| Variable for term of particular index in a data source | 1 | 1004 | February 9, 2021 | |
| Select only one value from list of values from a Template Variable in Grafana | 0 | 2400 | May 4, 2020 | |
| Element by index in variable for panel links | 3 | 3290 | October 21, 2021 | |
| Key -> value style for custom template variable configuration and usage | 15 | 20535 | October 27, 2020 |
