i would like to create links in dashboard panel with titles from each element stored system variable
custom variable “test” contains values A,B,C,D
and i would like to extract each element by index of their position something like:
{$test[0]} will have result: A
{$test[1]} will have result: B
etc
Thank you for any sugestions
Hi @jiripostulka
this question might be easier for another member to answer if you included more details. What datasource are you using, what does your query look like, and how are you setting your variable? Can you mock up this problem for others to try and solve using dummy data? I think more details here would help.
That said, I feel like you could drop template variables into queries that reference index positions using the JSON API datasource (assuming the data you are trying to parse is JSON…)
In this case datasource isn’t importent. but i will give you exact example
this is my variable
and my goal is in SQL query find out every records in table where column “test” had values ‘A’ or ‘B’ or ‘C’ or ‘D’
how can i get all selectable values in variable to query?
because this query return only test where is ‘A’
SELECT *
FROM mydb
WHERE mydb.test IN(‘${test}’);
I thing you will need to use a quer-type variable if toggling Include All option does not get you unblocked
