Access Grafana Cloud
Good Day,
Is it possible to enable anonymous access on a Grafana Cloud instance to share dashboards without needing to log in again
Thank You
Hendrik
Hi Hendrik - yes, for this type of public sharing, use the Snapshots feature in the share menu and click publish snapshot once you select the settings you’d like:
Check out this section of the docs for more info: Share dashboards and panels | Grafana documentation
Hope that helps! :slightly_smiling_face:
