When configure the 95th percentile when creating the dashboards, we found that the data is not accurate. Any links we can refer why its happen and is there any changes in influx DB queries?
Grafana version : 7.0.3
Grafana doesn’t support v7 anymore and v9 is light years ahead. Would highly recommend you try upgrading ![]()
Thank you Sir for the suggestion. will work on that.
