I’m encountering the following error in Grafana when using Loki as the data source:
504 Gateway Time-out504 Gateway Time-out
nginx/1.27.2
The full error message looks like this:
<html>
<head><title>504 Gateway Time-out</title></head>
<body>
<center><h1>504 Gateway Time-out</h1></center>
<hr><center>nginx/1.27.2</center>
</body>
</html>
This error occurs when I try to execute large queries on my Loki data source. Specifically, I see this issue when I attempt to query for a larger set of logs (e.g., 10,000 entries), while smaller queries (like 1,000 entries) execute successfully.
- Has anyone encountered the 504 Gateway Time-out error with Loki as a data source and found a resolution?
- Reduced the query limit to 1,000, which works fine, but I need a solution to handle larger queries (e.g., 10,000 logs).
