Hi all,
I’m working on grafana dashboard which is using infinity plugin as datasource. In one panel, 26 apis are calling. I’m getting 429 error which says too many request. Could you please advise?
This is not a problem with infinity, this is an issue on the api you are reaching out to, they seem to be rate limiting you, because of the amount of requests you are sending in such a short space of time. please reach out to them to see if what you are trying to achieve is supported. sometime depending on the api, you can pay for more requests per second, or they will provide a different endpoint that can handle more requests…
Thank you!
