Hi all, thanks in advance for any help – sure seems like I’m doing something wrong.
I’m getting a 404 when patching an annotation, using container grafana/grafana:5.4.3, which is the most recent docker image I could find here: https://hub.docker.com/r/grafana/grafana
See verbose curl output below for both the add and the patch…
THings I’ve tried:
- I get the same 404 result using both the “id” and the “endId”
- I get the same 404 result with and without the colon (":") prior to the id as shown in the documentation.
PATCH /api/annotations/:id
If “:id” in the doc is supposed to indicate that “id” is a data item that I supply…I don’t think the doc makes that point.
Thanks again,
–Erik
* About to connect() to myserver.com port 3200 (#0)
* Trying 1.1.1.1...
* Connected to myserver.com (1.1.1.1) port 3200 (#0)
> POST /api/annotations HTTP/1.1^M
> User-Agent: curl/7.29.0^M
> Host: myserver.com:3200^M
> Authorization: Bearer eyJrIjoidkd1emp6aURSN0sxRDFMeDZxTTVtcmVYMG05RGlT
> Accept: application/json^M
> Content-Type:application/json^M
> Content-Length: 147^M
> ^M
} [data not shown]
* upload completely sent off: 147 out of 147 bytes
< HTTP/1.1 200 OK^M
< Content-Type: application/json^M
< Date: Mon, 08 Apr 2019 12:15:19 GMT^M
< Content-Length: 51^M
< ^M
{ [data not shown]
* Connection #0 to host myserver.com left intact
\n response from adding grafana annotation: HTTP/1.1 200 OK^M Content-Type: application/json^M Date: Mon, 08 Apr 2019 12:15:19 GMT^M Content-Length: 51^M ^M {"endId":156,"id":155,"message":"Annotation added"}\n
* Trying 1.1.1.1...
> PATCH /api/annotations/155?endTime=1549792081000 HTTP/1.1^M
> ^M
< HTTP/1.1 404 Not Found^M
< Content-Type: application/json; charset=UTF-8^M
< Date: Mon, 08 Apr 2019 12:15:20 GMT^M
< Content-Length: 23^M
< ^M
{ [data not shown]
\n response from patching grafana annotation: HTTP/1.1 404 Not Found^M Content-Type: application/json; charset=UTF-8^M Date: Mon, 08 Apr 2019 12:15:20 GMT^M Content-Length: 23^M ^M {"message":"Not found"}\n
