MacOS 14.4
Browser: Firefox
Grafana: Grafana v11.0.0 (277ef258d4) -
For the panel to match itself in the grafana app. -
embedded grafana through reverse proxy. All other panels work. This particular panel is using cross-account data. (if that affects it) -
What happened?
Panel in embedded grafana UI is showing the error. -
Query built with “code” option. When using an ID of another query. The embedded panel version says that the ID is not found. But in the actual Grafana app where I modify the panel, there is no issue.
This is the query “code”
FILL(ebp,0) -
Error in the UI
metric request error: "ValidationError: Error in expression 'query16c3e4cf58294f6484dbd7d1d2db5ea5': ID 'ebp' not found\n\tstatus code: 400, request id: acb9b7e6-c7de-462c-b7c6-e4bcbd7c5b61
