There are two questions
- Why does the circle on the right not show the color? How can I set it to show the same color as the circle on the left
- The label below is not fully displayed, can you set the mouse hover and display all the label information
Welcome @pptfzo to the Grafana forum.
What are the 2 thresholds that you created? Please expand and post a screenshot (with the 4 gauges also displayed on the same screenshot).
Have you tried a Rename by regex transformation to fix the bottom labels to your liking? There are a lot of examples here on the forum.
What do you want the labels to show? For example: 10.0.0.10 or k8s-master01 ?
Thank you for your reply, but it didn’t work
Thank you very much, your method solved the problem, when I hover the mouse over one of the graphics, the full label will be displayed
I am a beginner, would like to ask, is there any other way, just mouse hover and display all the labels, is not through the link way, or when the formal environment to use the link more? Thank you
Each chart has a different feature; there is no other way than Data Link for Gauge Chart.
In the case of Stats Chart or Pie Chart, when your mouse hover, all labels are visible without any settings.
Usually, only the labels required for Legend are printed and used.
Okay, got it. Thank you very much
