I am using Grafana to display performance data from a few IBM i systems (formerly known as AS/400).
The data itself comes from Prometheus.
One of the things I display is the current load of active jobs in the system in %.
You can only have so much processes in the system before it shuts down.
I calculate this by using the following formula:
(Current Active Jobs * 100) / Maximum Possible Jobs
The actuall Math expression I use is this:
($CURJOBS * 100) / $MAXJOBS
I had Grafana v10.1.5 and updated to version Grafana v10.2.3.
After updating, I suddenly get the following error message for this calculation:
The thing is that I can’t seem to turn the warning off, nor do I have any idea how to resolve it.
The exclamation-mark-sign gets plastered all over my dashboard, which looks bad.
The calculation works and displays correct data - I have no use for this warning, it’s not even clear what it’s supposed to mean.
Googling the error message yields very few results from topics I made and one other guy on stackoverflow, nothing besides that.
I’m baffled almost noone else has this problem. I’ve rolled back to v10.1.5 and the problem is gone, aside some more super weird side effects like drop-down-menus not loading correctly.
I guess 10.2.3 is just a bad release not much people have yet.
Unions in SSE operations currently drop items when doing a binary operation (e.g. $A + $B) from either A or B when there isn’t a label “match” between them.
This is confusing, so to aid in this, we warn and display the count of items that where dropped, and which items they were.
IMHO you can have that math on the PromQL level, so you don’t need need to use expression.
