Grafana v9.2.3
Ubuntu 20.04 -
When zooming on a graph, I’d like one graph to remain nailed to a ‘last 30 days’ view. -
The ‘last 30 days’ view works perfectly when not zoomed. I wasn’t aware something had to be done to avoid zooming on a fixed timeframe graph. -
What happened?
The fixed timeframe graph couldn’t be rendered, it ran out of datapoints. Settingmin intervalto 5 minutes rather than leaving this default resolved that issue, but theRelative timevalue is ignored when zoomed.
The graph no longer shows “Last 30 days” in the top right when the timeframe is zoomed.
I expected theRelative timesetting to override any zoomed timeframes on the dashboard. -
n/a -
no -
no
The time series data source query is pretty simple:
from(bucket: "${bucket}")
|> range(start: v.timeRangeStart, stop: now())
|> filter(fn: (r) => r["_measurement"] == "mail.log")
|> filter(fn: (r) => r["program"] == "postfix/smtp")
|> filter(fn: (r) => r["_field"] == "postfix_dsn")
|> filter(fn: (r) => exists r.postfix_status)
|> group(columns: ["postfix_status"])
|> aggregateWindow(every: v.windowPeriod, fn: count, createEmpty: true)
