Zabbix top alerts in Grafana
I’m trying to understand how I can create a sample of top alerts generated in Zabbix but that are abrupt when they repeat.
From what I’ve seen, it’s possible for me to extract alerts but they are shown the same when we filter them in Zabbix itself.
Anyone?
Thanks!
Hello and welcome to the foruns,
There’s not really a reliable way of calculating the top alerts using the grafana-zabbix plug-in. The best solution here would be connecting Grafana to Zabbix Database using a SQL Plug-in and then using a SQL query to get the data directly from the database.
Hope it helps.
