Grafana version = 10.2.3
System = Centos 7
Grafana-Zabbix plugin version = 4.4.6 -
Add “Zabbix Probelm” visualization to my dashboard. -
Create new dashboard, add zabbix problem from visualization -
What happened?
Hello! There is an open question for this problem.
“Zabbix Problems Panel” display problems · Issue #1806 · grafana/grafana-zabbix (github.com)
Test with a more up-to-date system,centos 7 is already at the end of support in the next few months. Another test you can try is testing with a previous version of the plugin and grafana.
Hi, thanks for reply, I’d like to try an older version of grafana and plugin, which version might be more stable in your mind?
Try plugin version v4.4.6 and Grafana v10.4.0.
To install plugin specific version, used grafana-cli.
grafana-cli plugins install alexanderzobnin-zabbix-app 4.4.6
I tried to update Grafana to v10.4.0 and the issue is still there, I’d probably try an older version.
