I have recently installed Zabbix Plugin (Alexander Zobnin) to my local Grafana instance.
Even though I am able to enable the plugin and add as the datasource. Its even fetching the hosts groups etc. But I am not able to view any metrics data .
Brwoser debug tools , returning empty results array from zabbix api.
I have installed the following version.
Grafana CLI version 7.3.1
alexanderzobnin-zabbix-app @ 4.0.1
and zabbix API version 5.0.5
Does zabbix plugin has compatibility issue with the above versions.
Any help will be apprciated.
Regards
JT
