Dear All
When using Grafana’s Query as Zabbix and importing data, the graph is displayed normally in Zabbix, but the graph is not displayed normally in Grafana.
The reason appears to be that Grafana imports data from Trends_uint table.
I would like to inquire about the time conditions under which the from clause table is changed to history_unit → trends_uint.
Best Regards.
Thank you.
