Trends default changed to MAX
Hi!! I am currently using Grafana with Zabbix plugin. I noticed that when viewing a graph with a large amount of datapoints, it will average the data by default. Is there any way where it would take the maximum value instead of average? I know there is the function “trendValue(max)” that can be used, but I want to make it available for each dashboard I create by default.
Thanks!
Raisa
Not sure there is a way to change the default query behaviors for the zabbix data source.
Yes, there isn’t way to do that, but you can open issue on github, maybe it makes sense to add this option (default trend value) to Data Source config page.
Thank you both for your response!
I will open the issue and let you know in case of any changes.
