I have a panel with two y-axis, but I am unable to change the units of the axis. Every time I change it and hit the apply button, it remains at none. Here it what it looks like:
Any idea what could be wrong?
Hi @jbreitbart - have you tried using the Add series override button on the Panel edit menu? You should be able to set that for the series that isn’t plotting on the y-axis.
Same thing happens to me.
I have no axis name on the field tab. When I go Panel–>Axes–> Left (or right) axes and select a unit it is not persistent. I change the unit and select apply and nothing is changed. The axis names is still to none.
Same issue here
Had kWh as unit. Updated grafana to 7.4.3 and now unit keeps resetting to kWh no matter what I change it to.
