I am also trying to integrate with my GIT CID.
run:k6:
stage: run
environment: DEV
variables:
GIT_CHECKOUT: "false"
image:
needs:
- job: build:k6
script:
- go install go.k6.io/xk6/cmd/xk6@latest
- xk6 build --with github.com/grafana/xk6-output-prometheus-remote@latest
- ./k6 run -o xk6-prometheus-rw build/k6.bundle.min.mjs --vus ${K6_VUS} --iterations ${K6_ITERATIONS} -e K6_HOSTNAME=$K6_HOSTNAME -e K6_BASEPATH=$K6_BASEPATH
artifacts:
reports:
junit: junit.xml
when: manual
But when pipeline run getting below error, And I have no idea about go.
go: downloading google.golang.org/genproto v0.0.0-20230110181048-76db0878b65f
2023/07/19 12:50:56 [INFO] exec (timeout=0s): /usr/local/go/bin/go mod tidy -compat=1.17
2023/07/19 12:50:56 [INFO] Writing main module: /tmp/buildenv_2023-07-19-1250.1174414957/main.go
2023/07/19 12:50:56 [INFO] exec (timeout=0s): /usr/local/go/bin/go mod edit -require go.k6.io/k6@0.44.1
go: errors parsing go.mod:
/tmp/buildenv_2023-07-19-1250.1174414957/go.mod:27:2: require go.k6.io/k6: version "0.44.1" invalid: unknown revision 0.44.1
2023/07/19 12:51:01 [INFO] Cleaning up temporary folder: /tmp/buildenv_2023-07-19-1250.1174414957
2023/07/19 12:51:01 [FATAL] exit status 1
