I have Go & k6 installed
Then, I want to monitoring test result in Prometheus, so I install xk6 through GO, and try to build xk6-output-prometheus-remote.
The xk6 seems to be installed successfully:
, and also under GOPATH.:
.asdf/installs/golang/1.17.3/packages/pkg/mod/go.k6.io/xk6@v0.5.0
But I tried to xk6 build --with github.com/grafana/xk6-output-prometheus-remote accordingly to instruction, I bo received:
zsh: command not found: xk6
Can you tell me what adjustments I should make? Or missing something?
Thanks!
