Xk6 Kafka Message - Sasl Auth parameters
Hi
We are currently using Neoload for testing Kafka messages, and want to migrate to k6.
We use below auth parameters, via a kafka.properties file. How can we replicate these settings in k6.
bootstrap.servers=
schema.registry.url=
security.protocol=SASL_SSL
sasl.mechanism=OAUTHBEARER
sasl.oauthbearer.token.endpoint.url=
sasl.jaas.config=
sasl.login.callback.handler.class=org.apache.kafka.common.security.oauthbearer.secured.OAuthBearerLoginCallbackHandler
bearer.auth.logical.cluster=
bearer.auth.credentials.source=SASL_OAUTHBEARER_INHERIT
clientId=
auto.register.schemas=false
value.serializer=com.platform.kafka.common.serde.KafkaAvroCloudEventSerializer
key.serializer=org.apache.kafka.common.serialization.StringSerializer
interceptor.classes=io.cloudevents.kafka.PartitionKeyExtensionInterceptor,
com.marriott.platform.kafka.common.interceptor.PlatformProducerInterceptor
request.timeout.ms=990000
acks=all
cloudevents.serializer.encoding=BINARY
Hi @nikhil8831 this will be better asked in the xk6-kafka repository.
