Trying to use the k6 kafka plugin to route the results to Azure Event Hub (which has a kafka head enabled) . So to use event hub with kafka we need to set some variables as provided in this link:
The kafka client configs need to be changed if they have to work with event hubs in azure
bootstrap.servers=mynamespace.servicebus.windows.net:9093
request.timeout.ms=60000
security.protocol=SASL_SSL
sasl.mechanism=PLAIN
sasl.jaas.config=org.apache.kafka.common.security.plain.PlainLoginModule required username="$ConnectionString" password="{YOUR.EVENTHUBS.CONNECTION.STRING}";
Is there a way to provide this settings to the Kafka client used by K6? Or how can we extend the k6 plugin to enable this?
