I am trying to use xk6-sql module in my project and running the command > xk6 build --with GitHub - grafana/xk6-sql: Use SQL databases from k6 tests.
I am getting the below error.
2023/04/20 10:09:33 exec (timeout=0s): C:\Program Files (x86)\Go\bin\go.exe build -o <project_path>\k6.exe -ldflags=-w -s -trimpath
github.com/grafana/xk6-output-prometheus-remote/pkg/remote
........\go\pkg\mod\github.com\grafana\xk6-output-prometheus-remote@v0.1.0\pkg\remote\client.go:120:35: cannot use 0xffffffff (untyped int constant 4294967295) as int value in argument to fmt.Errorf (overflows)
2023/04/20 10:09:36 Cleaning up temporary folder: C:\Users<user>\AppData\Local\Temp\buildenv_2023-04-20-1009.338902461
2023/04/20 10:09:36 FATAL exit status 1
Go version 1.20.3
Environment - Windows
