I am attempting to run a very simple test which is having issues due to err:net::ERR_CERT_AUTHORITY_INVALID while trying to load the page.
Background:
I am trying to open a webpage of a company’s webapp hosted on a remote machine. The app is behind and NGINX which is used for SSL termination and provides the certificates (fully chained), with the organization root certificate inside the trusted root store of the windows machines. When you go to the URI, for example: https://mywebapp.company.local , it does a redirect to a login page but uses the company’s fully chained certificate. I am then trying to output results to Prometheus and Grafana. I’ve been trying everything for several days to get it to work but unfortunately it’s always getting the certificate error. On the side of the app server with the nginx, the nginx error log prints out:
[info] 6440#2356: *17 SSL_do_handshake() failed (SSL: error:14094412:SSL routines:ssl3_read_bytes:sslv3 alert bad certificate:SSL alert number 42) while SSL handshaking, client: 192.1.1.1, server: 0.0.0.0:443
Note: the following docker files work for API testing against this remote machine (correct certificate), but the issue happens when trying to use the browser. Also note, the code runs just fine when using xk6-browser.exe instead of docker.
Here are my dockerfile, dockercompose, and test code:
dockerfile:
FROM golang:1.19-bullseye as builder
RUN go install -trimpath go.k6.io/xk6/cmd/xk6@latest
RUN xk6 build --output "/tmp/k6" --with github.com/grafana/xk6-browser@main
FROM debian:bullseye
RUN apt-get update && \
apt-get install -y chromium &&\
apt install -y libnss3-tools curl &&\
apt-get install -y ca-certificates
COPY ./certs/fullychained.crt /usr/local/share/ca-certificates/fullychained.crt
COPY ./certs/rootca.crt /usr/local/share/ca-certificates/rootca.crt
RUN chmod 644 /usr/local/share/ca-certificates/fullychained.crt && \
chmod 644 /usr/local/share/ca-certificates/rootca.crt && \
update-ca-certificates
COPY --from=builder /tmp/k6 /usr/bin/k6
ENV XK6_HEADLESS=true
ENTRYPOINT ["k6"]
And here is the docker compose:
version: '3.8'
networks:
k6:
grafana:
prometheus:
services:
prometheus:
image: prom/prometheus:v2.40.7
command:
- --web.enable-remote-write-receiver
- --enable-feature=native-histograms
- --config.file=/etc/prometheus/prometheus.yml
networks:
- k6
- grafana
- prometheus
ports:
- "9090:9090"
grafana:
image: grafana/grafana:9.3.2
networks:
- grafana
- prometheus
ports:
- "3000:3000"
environment:
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_BASIC_ENABLED=false
# - IGNORE_HTTPS_ERRORS=true
volumes:
- ./grafana:/etc/grafana/provisioning/
k6-browser:
build: .
networks:
- k6
ports:
- "6565:6565"
- "443:443"
- "80:80"
environment:
- K6_PROMETHEUS_RW_SERVER_URL=http://prometheus:9090/api/v1/write
- K6_PROMETHEUS_RW_TREND_AS_NATIVE_HISTOGRAM=true
- K6_OUT=experimental-prometheus-rw
depends_on:
- prometheus
volumes:
- ./samples/Login.js:/Login.js
- ./samples/users.json:/users.json
- ./screenshots/:/screenshots/
- ./certs/fullychained.crt:/fullychained.crt
- ./certs/rootca.crt:/rootca.crt
command: run /Login.js --tag testid=logintest
And the code:
import { check, sleep } from 'k6';
import { chromium } from 'k6/x/browser';
import { SharedArray } from 'k6/data';
import { vu } from 'k6/execution';
const usersData = new SharedArray('users', function () {
return JSON.parse(open('./users.json')).users;
export const options = {
httpDebug: 'full',
scenarios: {
login: {
executor: 'per-vu-iterations',
vus: 1,
iterations: 1,
maxDuration: '1h30m',
export default function () {
const browser = chromium.launch({ headless: true, debug: true });
const context = browser.newContext();
const page = context.newPage();
page.goto('https://mywebapp.company.local ', { waitUntil: 'networkidle' });
page.screenshot({path: '/screenshots/01_screenshot.jpg'});
When I open up the docker terminal and CURL to the URI, it does a successful certificate handshake
If anyone has any pointers or solutions, I would be most grateful. Thanks!
