Hello!
I have been working on writing a Dockerfile so that I can run a xk6-browser test that I have written, but am having a lot of trouble with getting the Dockerfile to build and run properly. To create my Dockerfile, I have referenced this forum post: http://grafana.staged-by-discourse.com/t/xk6-browser-in-docker/95919/. Then to build my Dockerfile I have been running: docker build -t testing-xk6 . . However, each time I run into the following issue:
<b>[#9](https://grafana.zendesk.com/tickets/9) 76.94 cp: omitting directory 'k6'
executor failed running [/bin/sh -c apk --no-cache add git && go install -trimpath [go.k6.io/xk6/cmd/xk6@latest](http://go.k6.io/xk6/cmd/xk6@latest) && xk6 build --output /k6 --with [github.com/grafana/xk6-browser](http://github.com/grafana/xk6-browser) && cp k6 "$GOPATH"/bin/k6]: exit code: 1</b>
I tried to add “-r” to the line cp k6 "$GOPATH"/bin/k6 in my Dockerfile (see below) and it seemed to work (as in the Dockerfile successfully built), however now I am running into the following issue when trying to run my test in the container:
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: exec: "k6": executable file not found in $PATH: unknown.
I am running my test with the command:
docker run --rm -i -v /Users/jlombardi/testingxk6/k6:/k6 testing-xk6 k6 run loginPageBrowserTest.js
Since I am still running into errors, I am not sure that my fix with adding “-r” actually fixed anything
My Dockerfile is pasted below. Thanks so much in advance.
FROM golang:1.18-alpine as builder
WORKDIR "$GOPATH"/src/go.k6.io/k6
COPY . .
RUN apk --no-cache add git &&\
go install -trimpath go.k6.io/xk6/cmd/xk6@latest &&\
xk6 build --with github.com/grafana/xk6-browser &&\
cp -r k6 "$GOPATH"/bin/k6
RUN apk add chromium
FROM alpine:3.15
RUN apk add --no-cache ca-certificates && \
adduser -D -u 12345 -g 12345 k6
COPY --from=builder /go/bin/k6 /usr/bin/k6
USER 12345
CMD [""]
