Hi there.
I want to make a graph that displays hourly forecasts (temperature, rain, etc.). I have data coming from OpenHAB that saves in a InfluxDB2 database. For each forecast, I have the following in InfluxDB:
weather_hXX_temperature
weather_hXX_humidity
weather_hXX_timestamp
where XX is a number between 00 (now) and 48 (hours). I can retrieve the data in Grafana with:
from(bucket: “openhab”)
|> range(start: -2h)
|> filter(fn: (r) =>
r._measurement =~ /weather_h[0-4][0-9]_temperature/
|> last()
I want to make a graph that uses weather_hXX_timestamp on the X axis, and weather_hXX_temperature on the Y axis. Seems simple enough, but I can’t figure it out. Note there are no missing values in the ranges, they include all values from 00 to 48.
I read:
and a few others
and installed Plotly for Grafana 7.5.4: Plotly panel plugin for Grafana | Grafana Labs, but I’m not familiar with javascript, I typically do embedded stuff.
I can’t wrap my head around this. Where to start?
Any help will be greatly appreciated
