Hi
I have a problem that is driving me crazy with worldmap.
I have alredy create a map using the geoash data from my elasticsearch DB, it work without any problem with grafana and kibana also.
The problem comes when i try to associate the location name with the point in the map… simpy doesn’t work and i can’t understand why! I have paste/copied the configuration in the guide.
The field in the DB SHOULD be correct, I have all the field that are required to create an association between the 2 element
Someone have any idea? Let me know if you need more info.
Thanks
Remided
