I added Elasticsearch (5.x) data source in Grafana, and I installed the WorldMap plugin.
As I started plotting data, I noticed that when I hover over the point in the map it shows with some sort of hash “dpz3j: ”
How do I change the dpz3j and put like a city name from an elastic search field.
You need to provide a Location Name, see world map panel readme:
Three fields need to be provided by the ElasticSearch query:
- A metric. This is free text and should match the aggregation used (Count, Average, Sum, Unique Count etc.)
- Location Name (optional - geohash value will be shown if not chosen)
- geo_point field that provides the geohash value.
Marcus
