Why cannot I make a dashboard public? What are template variables?
    v10.2.3 MacOS Sonoma 14.2.1
    Make a dashboard public.
  • What happened?
    A letter appeared saying the dashboard has template variables on it.
    This is the only template variable I set:
    Then, I had interpolated variable values within queries, such as:
who created this dashboard?
I did! Please, notice that I have just edited the post to include more information on the issue.
is that variable used? what is it’s purpose?
Yes, it is. The idea is to set it to the same value as another variable. I tried deleting it and still couldn’t make the dashboard public for the same reason.
maybe you deleted but did not save. anyways might want to check the following if you have not already
Any idea on what are “template variables”?
Template variables are variables that are used in Templates (saved queries with variables). See documentation Variables | Grafana documentation
I have a dashboard with many variable dropdown menus and full of queries like this (using an Infinity data source): [GET] /controller/rest/applications/${appName}/metric-data?metric-path=Business%20Transaction%20Performance%7CBusiness%20Transactions%7C${tier_A}%7C${bt_A}%7CErrors%20per%20Minute&time-range-type=BETWEEN_TIMES&start-time=${__from}&end-time=${__to}&output=JSON&rollup=false.
Is there any chance of converting this kind of dashboard (and its panels) into something I can then publish?
Each of the variables contains several values that come from HTTP requests; so do the panel queries. That’s why I implemented template variables.
Currently public dashboards do not support template variables. However, we are in discussion on providing that support, if feasible.
hi, have you fix this problem?
this is a features that will be very comfortable for setting dynamic values on the all dashboards.
Regards.
Looking forward to the “Template Variable on Public Dashboard” feature :eyes:
Well someone tagged this as solved :slight_smile: But it’s still an issues and it’s making public dashboard virual unusable. We would like to show dasboards on our signage screens but not possible now.
Please, it would be super useful to have this feature
