Hello All,
I was using Grafana v6.8.x and upgraded to v7.0.0. I had few of my panel visualization displaying as time series table format. In Grafana v6.8.x, I was able to format my date column with YYYY-MM-DD. But after upgrading to v7.0.0 I am not able to format the same data.
Also, when I open my panel displaying timeseries data in tabular format, the column styles are showing but in visualization the table option is not selected though which I selected in v6.8. If I select table then the column style is gone from Panel tab.
Below are the screenshots of the issue:
Panel:
Grafana v7.0 - Where can i select the date format as YYYY-MM-DD
Panel developed in Grafana v6.8 when opened in v7.0.0, I can see the column styles option under Panel which is not supported or showing in v7.0.0
How can I set the column styles for a column in v7.0.0 like I used to set with v6.8.x. For example, a column of Date type with Date format as YYYY-MM-DD?
Please help!
Regards,
Sudeep
