Where is this port 53 coming from?
Wondering if anyone has encountered this error before:
Post “http://lx-4:9095/api/v1/query”: dial tcp: lookup lx-4 on 138.153.159.32:53: server misbehaving - There was an error returned querying the Prometheus API.
Latest version and Linux.
To connect my Prometheus server / data source to my Grafana server.
By filling out the add data source connection form in the UI and clicking “Save & Test” at the bottom.
  • What happened?
I get error: There was an error returned querying the Prometheus API
The connection to be successful.
global:
scrape_interval: 15s
scrape_configs:
  • job_name: ‘prometheus’
    static_configs:
    • targets: [‘lx-4:9095’]
Port 53 is for DNS usually. So your error message indicates that there was a problem to resolve record lx-4 by using DNS server 138.153.159.32. So make sure youu have correct DNS configuration on the machine where this Prometheus is running.
Sorry I forgot to mention I am running both Grafana and Prometheus as Docker containers.
It doesn’t matter. You(Prometheus) wants to connect to some DNS name - e.g. www.google.com (in your case lx-4), so system must know IP address where to connect. If you are using Docker, then is Docker documentation is the right doc for this use case.
But isn’t lx-4 and it’s IP address used interchangeably in this context?
