Where is the server log file when using grafana web?
Hi, I am trying to connect to mySql datablase, i am using grafana web version.
The datasource is not connecting and the message is “Query failed. Please inspect Grafana server log for details”. The docs explains “If you encounter an error or problem, then you can check the Grafana server log. Usually located at /var/log/grafana/grafana.log on Unix systems or in <grafana_install_dir>/data/log on other platforms and manual installations.” But where I can find the server log in the grafana web version?
Thanks in advance.
did you find where is the log file located ? Even i have the same problem
Thanks
Nagashree
Hi, did you find where is the log page? “<>/var/log/grafana/grafana.log” this link is giving 404 error.
hi. ı am also searching but couldnt find.
hi tried with some path but did not find can you suggest what should i do here??
I’m the same, I can’t connect any database and I don’t know what step I’m making a mistake.
and it shows me this query error.
Hi @lauratardivo,
Welcome to the :grafana: community support forums !!
Regarding your query;
The logs are only available at the backend server where the Grafana is installed for e.g. If your Grafana Server is using a Linux Virtual Machine or Docker or AWS etc, then all the server logs will be available on that server. The documentation is valid i.e. :
The WebUI only show a short message.
I hope this answer your question.
But if I’m using Grafana’s cloud version… how do I access the logs?
To be clear - nothing is installed on my machine. I’m using the cloud version via grafana.net. There is no local filepath to go to.
Are you using the free Grafana cloud or the paid one?
I’m using the free Grafana cloud and also trying to view the logs. Specifically because I’m trying to setup a postgresql connection and getting the error “failed to connect to server - please inspect Grafana server log for details”
So how do I view the server logs?
Thanks.
I will move this post to the Grafana Cloud as folks there can help you more as what is the way to see cloud logs.
Hello folks,
For Grafana Cloud server logs are only accessible to support staff.
To reconfigure a datasource and test its connection you can select it from the connect data page in your Grafana Cloud instance. From there you can test the integration connection.
https://YOURORG.grafana.net/connections/connect-data/mysql
To check logs from the Grafana agent, you can find them at:
var/log/grafana-agent.err.log
From these logs you can see the connections and telemetry attempts made by Grafana agent and any resulting errors.
Similar to the following:
caller=exporter.go:155 level=error integration=mysqld_exporter msg="Error pinging mysqld" err="Error 1045: Access denied for user 'root'@'172.17.0.1' (using password: YES)"
Once the integration has been established you can do 3 things.
  • Make queries to MySQL as a datasource.
  • Query your Grafana Cloud Prometheus instance for exported mysql metrics
  • Query your Grafana Cloud Loki instance for mysql’s server logs
Take a look at the logs in explore feature for more information on how to query and filter logs that have been ingested.
I am also interested in a solution here. I cannot connect to the database, with a message “query failed - please inspect Grafana server log for details”
If the logs are only accessible to support staff, what is the purpose of this message? Can you just tell me what the error is instead of telling me to look for the server log?
Same, I am experiencing the same issue as well.
Have you white-listed all IPs that Grafana has listed on their site?
Working with Grafana Cloud Support, they actually realized they were missing two IP addresses that are required to be white-listed: 3.129.236.235 and 3.21.150.93
Once I added those to my white-list on my Google Cloud postgresql server instance, I was able to get the postgresql connection established within Grafana!
Grafana says they are working on getting those two IP addresses added to their docs site, I’m not sure what’s taking them so long.
