Read server logs
I’m trying to setup a MySQL datasource, but after filling-up the configuration fields I click on Save & Test and I get a Query failed. Please inspect Grafana server log for details.
I cannot access the computer running Grafana, I can only access Grafana service, so hopefully I would not need to read a /var/logs location.
I would need more details about what is going on. Do you know how can I access the log?
Grafana version: Grafana v6.5.1 (commit: 1763a0f)
Hello @emessina are you able to connect to the MySql data source? I am getting the same error and not able to trace logs file.
