I am running grafana from master because I wanted to do some quick hacking on the png-renderer feature. However it fails with:
Can't open '/Users/<snip>/go/src/github.com/grafana/grafana/vendor/phantomjs/render.js'
When I look for the file in the repo or build output I find nothing relevant:
/Users/<snip>/go/src/github.com/grafana/grafana $ find -L . -name render.js
./node_modules/enzyme/build/render.js
./node_modules/enzyme/render.js
./node_modules/enzyme/src/render.js
./node_modules/enzyme-to-json/render.js
./node_modules/node-sass/lib/render.js
Kind regards,
Mikael
