I am storing 500 MB of logs (at once and a few MB of logs add up daily) in Loki using Promtail.
I need to gather logs annually to do a report but when querying Loki with LogCLI (I use Minio to store the logs with Loki) there are a lot of missing logs, I get around 5MB of logs when it should be around 500MB.
I have a few questions: Is it a good practice to store logs like that using Loki to do reporting? Loki works well for logs monitoring in live but am I not using it correctly/not for the right purpose when it comes to storing logs on long periods to do annual reports? maybe I should use another system to store the logs for reporting? How do most users do reports from their logs?
Anyways, I set the retention period to a year and indeed when querying I have logs that are old (11 months) but there are still missing ones that should be present in that year.
Here is my config:
auth_enabled: false
server:
http_listen_port: 3100
distributor:
ring:
kvstore:
store: memberlist
ingester:
max_chunk_age: 168h
chunk_idle_period: 168h
chunk_target_size: 3145728
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
final_sleep: 0s
wal:
enabled: true
dir: /loki/wal
memberlist:
abort_if_cluster_join_fails: false
bind_port: 7946
join_members:
- loki:7946
max_join_backoff: 1m
max_join_retries: 10
min_join_backoff: 1s
schema_config:
configs:
store: tsdb
object_store: s3
schema: v12
index:
prefix: index_
period: 24h
storage_config:
tsdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
resync_interval: 5s
shared_store: s3
aws:
s3: http://<minioadmin>:<minioadmin>@minio.:9000/loki
s3forcepathstyle: true
limits_config:
enforce_metric_name: false
reject_old_samples: false
reject_old_samples_max_age: 0h
retention_period: 365d
compactor:
retention_enabled: true
working_directory: /loki/compactor
shared_store: aws
query_scheduler:
max_outstanding_requests_per_tenant: 32768
querier:
max_concurrent: 16
ruler:
alertmanager_url: http://localhost:9093
Thank you for your help, I feel like there is something I don’t understand about Loki when it comes to logs and reporting/logs analytics (not log monitoring).
I don’t think there is any problem with storing logs for long period of time. I am sure there are people storing logs for just as long, if no longer, than you do, with a lot more volume.
What is your storage usage on Minio? Do you see the expected amount of storage used? Also print out the current configuration with the /config API endpoint, and review all limits configuration (such as max_query_length).
The minio bucket for Loki is 1.5MB. I am guessing that it is less because it’s compressed, but it is still very low.
Here is my limits_config:
limits_config:
ingestion_rate_strategy: global
ingestion_rate_mb: 4
ingestion_burst_size_mb: 6
max_label_name_length: 1024
max_label_value_length: 2048
max_label_names_per_series: 30
reject_old_samples_max_age: 0s
creation_grace_period: 10m
max_line_size: 0
max_line_size_truncate: false
increment_duplicate_timestamp: false
max_streams_per_user: 0
max_global_streams_per_user: 5000
unordered_writes: true
per_stream_rate_limit: 3145728
per_stream_rate_limit_burst: 15728640
max_chunks_per_query: 2000000
max_query_series: 500
max_query_lookback: 0s
max_query_length: 30d1h
max_query_parallelism: 32
tsdb_max_query_parallelism: 512
cardinality_limit: 100000
max_streams_matchers_per_query: 1000
max_concurrent_tail_requests: 10
max_entries_limit_per_query: 5000
max_cache_freshness_per_query: 1m
max_queriers_per_tenant: 0
query_ready_index_num_days: 0
query_timeout: 5m
split_queries_by_interval: 30m
min_sharding_lookback: 0s
ruler_evaluation_delay_duration: 0s
ruler_max_rules_per_rule_group: 0
ruler_max_rule_groups_per_tenant: 0
ruler_alertmanager_config: null
ruler_tenant_shard_size: 0
ruler_remote_write_disabled: false
ruler_remote_write_url: ""
ruler_remote_write_timeout: 0s
ruler_remote_write_headers: {}
ruler_remote_write_queue_capacity: 0
ruler_remote_write_queue_min_shards: 0
ruler_remote_write_queue_max_shards: 0
ruler_remote_write_queue_max_samples_per_send: 0
ruler_remote_write_queue_batch_send_deadline: 0s
ruler_remote_write_queue_min_backoff: 0s
ruler_remote_write_queue_max_backoff: 0s
ruler_remote_write_queue_retry_on_ratelimit: false
ruler_remote_write_sigv4_config: null
deletion_mode: filter-and-delete
retention_period: 1y
per_tenant_override_config: ""
per_tenant_override_period: 10s
allow_deletes: false
shard_streams:
enabled: false
logging_enabled: false
desired_rate: 3145728
Are you sure your logs are actually stored in minio? Since you are setting maximum chunk age to 7 days, try querying for anything past 7 days and see if there is any result.
I suspect your storage configuration may be incorrect. If you expected 500MB of total logs then your minion storage should definitely have more than 1.5MB in there. Check and see what’s actually on your minion storage as well.
