I use latest grafana on a windows machine.
In my barchart I have a small i-icon in the top left corner:
If I hover the mouse over this i then I can see a small speech bubble appearing above the barchart. But there is no text inside.
What is this i-icon telling me?
I still need help on this issue - may someone (from Grafana team) can assist please?
@mrburns The āiā icon holds the content of the description field from the panel options. Since the bubble is showing up but is empty you may have inadvertently added a space to the description field at some point while editing. Removing that should clear your issue.
See my screenshot for example of what may be the issue:
