Environment:
I am using grafana and its sidecar component in a kubernetes cluster.
I have two different dashboard providers as follows:
dashboardProviders:
dashboardproviders.yaml:
apiVersion: 1
providers:
- name: 'dpa'
orgId: 1
folder: 'Dashboards A'
type: file
disableDeletion: false
updateIntervalSeconds: 10
editable: true
options:
path: /var/lib/grafana/dashboards/dpa
- name: 'dpb'
orgId: 1
folder: 'Dashboards B'
type: file
editable: true
options:
path: /var/lib/grafana/dashboards/dpb
and here is the relevant part of my sidecar configuration:
sidecar:
dashboards:
enabled: true
folder: /var/lib/grafana/dashboards/
defaultFolderName: dpa
With this configuration in mind, when I provide a configmap (containing the dashboard) with the annotation below, it is working fine:
annotations:
k8s-sidecar-target-directory: “/var/lib/grafana/dashboards/dpa”
I assumed if I am not providing any target directory, the dashboard json file should go to the defaultFolderName directory (in my case “dpa”) that I have defined. However, the json files are saved in the root directory (/var/lib/grafana/dashboards/).
I have two questions:
1- is my assumption wrong about the defaultFolderName usage?
2- if it is wrong, is there any other way to provide such functionality the dashboards can be configured to be set in different directory while there is also a default directory for the dashboards that are not configured?
Thanks
