What is the correct pipeline stage for `kubernetes_sd_configs`?
The following Promtail documentation recommends docker: {} pipeline stage for kubernetes_sd_configs
However, the official Grafana’s helm chart that deploys Promtail uses cri: {} pipeline stage:
helm template my-release grafana/loki-stack > output.yaml
That means Grafana’s documentation and Grafana’s helm chart supposed to be equivalent, but they use different pipeline stages. I am not sure which one should I trust.
What is the correct pipeline stage I should use for kubernetes_sd_configs?
PS:
For the reference, here is the configuration that Grafana’s Promtail helm chart produces:
    server:
      log_level: info
      log_format: logfmt
      http_listen_port: 3101
    clients:
      - url: http://my-release:3100/loki/api/v1/push
    positions:
      filename: /run/promtail/positions.yaml
    scrape_configs:
      # See also https://github.com/grafana/loki/blob/master/production/ksonnet/promtail/scrape_config.libsonnet for reference
      - job_name: kubernetes-pods
        pipeline_stages:
          - cri: {}
        kubernetes_sd_configs:
          - role: pod
        relabel_configs:
          - source_labels:
              - __meta_kubernetes_pod_controller_name
            regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
            action: replace
            target_label: __tmp_controller_name
          - source_labels:
              - __meta_kubernetes_pod_label_app_kubernetes_io_name
              - __tmp_controller_name
              - __meta_kubernetes_pod_name
            regex: ^;*([^;]+)(;.*)?$
            action: replace
            target_label: app
          - source_labels:
              - __meta_kubernetes_pod_label_app_kubernetes_io_instance
              - __meta_kubernetes_pod_label_instance
            action: replace
            target_label: instance
          - source_labels:
              - __meta_kubernetes_pod_label_app_kubernetes_io_component
              - __meta_kubernetes_pod_label_component
            action: replace
            target_label: component
          - action: replace
            source_labels:
            - __meta_kubernetes_pod_node_name
            target_label: node_name
          - action: replace
            source_labels:
            - __meta_kubernetes_namespace
            target_label: namespace
          - action: replace
            replacement: $1
            separator: /
            source_labels:
            - namespace
            - app
            target_label: job
          - action: replace
            source_labels:
            target_label: pod
          - action: replace
            source_labels:
            - __meta_kubernetes_pod_container_name
            target_label: container
          - action: replace
            replacement: /var/log/pods/*$1/*.log
            separator: /
            source_labels:
            - __meta_kubernetes_pod_uid
            target_label: __path__
          - action: replace
            regex: true/(.*)
            separator: /
            source_labels:
            - __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
            - __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
