What is config.color.fixedColor for nodegraph
Hello
Using data coming from mysql all looks well when plotting it in nodegraph but the colors are not working out as expected per documentation.
So I wanted to try config.color.fixedColor, but not sure where I configure that?
    8.5.2
    different colors for different values in nodegraph
    by using the appropriate data for the Data Api that should handle colors based on data values
  • What happened?
    it does not work colors are all the same
    show different colors depending on the data values
    not sure how?
    I don’t see any errors.
    Node graph | Grafana documentation
@yosiasz I looked into this one for you and noticed that there aren’t any options yet to configure the colors. I found this PR which will add options to configure the color:
Yep, I created that issue :blush:
