9.2.3 -
Hi geeks, I want to know what the mechanism for password encryption is. After
starting a Grafana process, I add a data source for Grafana. Then, the
process will insert a record into the metadata. For defaults, the metadata
stored in data/grafana.db, using SQLite, and the data source record is stored
in the table data_source. One of the table fields is
secure_json_data which records ciphertext for the connection password.
It looks using symmetrical encryption, I think.
I want to know how to decrypt this ciphertext.
And I wonder how I can add a new
data source using a command line. I only understand users can update that using the website, it is not a friendly approach for developers.
As posted above. -
What happened?
None -
None -
None -
None -
None
