v9.2.2 -
pass encrypted passwords in datasource configuration, not the direct password -
What happened?
I can’t find a mechanism to encrypt passwords that the infinity datasource configuration would accept as it. -
get to know some command or mechanism to encrypt passwords that the infinity datasource would accept as it.
Have you tried reaching out to the infinity plugin’s maintainer ?
The Infinity plugin’s authentication methods is all I could find
Hi!! Thank you!
Yes, I read the authentication methods and it doesn’t seem to talk about it. I’ve just posted my issue in the infinity plugin’s maintainer. Thanks!
