WeatherKit API forecastStart value
Is there a way to take an API’s datasource result value that is a UTC based time and convert it to a local timezone? This isn’t stored in a database, it’s the Apple WeatherKit I am setting up as a datasource and even though it’s giving me today’s data, Apple doesnt adjust the forecastStart to be local to the timezone requested. It just provides me the data that is adjusted to my timezone.
Hopefull that makes sense.
This honestly cant be a new problem, can it?
welcome
Please provide some sample data, I am not sure I understand
So the weatherkit api call returns an hourly dataset that includes the time (forecastStart) but in UTC. Even though the data is from the time of which you want, apple returns the UTC time which doesnt work real well when I have no way to offset that output to my local timezone.
    "forecastHourly": {
        "name": "HourlyForecast",
        "metadata": {
            "attributionURL": "https://weatherkit.apple.com/legal-attribution.html",
            "expireTime": "2023-01-08T19:21:16Z",
            "latitude": 27.499,
            "longitude": -82.575,
            "readTime": "2023-01-08T18:21:16Z",
            "reportedTime": "2023-01-08T17:00:00Z",
            "units": "m",
            "version": 1
        "hours": [
                "forecastStart": "2023-01-08T18:00:00Z",
                "cloudCover": 0.10,
                "conditionCode": "Clear",
                "daylight": true,
                "humidity": 0.59,
                "precipitationAmount": 0.0,
                "precipitationIntensity": 0.0,
                "precipitationChance": 0.00,
                "precipitationType": "clear",
                "pressure": 1022.55,
                "pressureTrend": "falling",
                "snowfallIntensity": 0.00,
                "snowfallAmount": 0.00,
                "temperature": 23.41,
                "temperatureApparent": 23.60,
                "temperatureDewPoint": 14.90,
                "uvIndex": 5,
                "visibility": 32781.00,
                "windDirection": 128,
                "windGust": 14.46,
                "windSpeed": 8.53
                "forecastStart": "2023-01-08T19:00:00Z",
                "cloudCover": 0.14,
                "conditionCode": "MostlyClear",
                "daylight": true,
                "humidity": 0.58,
                "pressure": 1021.57,
                "temperature": 23.88,
                "temperatureApparent": 24.10,
                "temperatureDewPoint": 15.02,
                "uvIndex": 4,
                "visibility": 33233.87,
                "windDirection": 156,
                "windGust": 14.30,
                "windSpeed": 7.56
                "forecastStart": "2023-01-08T20:00:00Z",
                "cloudCover": 0.12,
                "daylight": true,
                "humidity": 0.58,
                "pressure": 1020.91,
                "temperature": 23.65,
                "temperatureApparent": 23.86,
                "temperatureDewPoint": 14.96,
                "uvIndex": 3,
                "visibility": 31874.48,
                "windDirection": 210,
                "windGust": 15.15,
                "windSpeed": 8.40
                "forecastStart": "2023-01-08T21:00:00Z",
                "cloudCover": 0.11,
                "daylight": true,
                "humidity": 0.61,
                "pressure": 1020.57,
                "temperature": 22.89,
                "temperatureApparent": 23.11,
                "temperatureDewPoint": 15.03,
                "uvIndex": 1,
                "visibility": 30864.05,
                "windDirection": 230,
                "windGust": 14.97,
                "windSpeed": 9.33
                "forecastStart": "2023-01-08T22:00:00Z",
                "cloudCover": 0.08,
                "daylight": true,
                "humidity": 0.66,
                "pressure": 1020.59,
                "temperature": 21.77,
                "temperatureApparent": 22.01,
                "temperatureDewPoint": 15.21,
                "uvIndex": 0,
                "visibility": 30260.75,
                "windDirection": 236,
                "windGust": 13.98,
                "windSpeed": 9.71
                "forecastStart": "2023-01-08T23:00:00Z",
                "cloudCover": 0.10,
                "daylight": false,
                "humidity": 0.75,
                "pressure": 1020.94,
                "pressureTrend": "steady",
                "temperature": 19.80,
                "temperatureApparent": 20.02,
                "temperatureDewPoint": 15.16,
                "uvIndex": 0,
                "visibility": 28831.43,
                "windDirection": 264,
                "windGust": 11.83,
                "windSpeed": 8.48
                "forecastStart": "2023-01-09T00:00:00Z",
                "cloudCover": 0.07,
                "daylight": false,
                "humidity": 0.80,
                "pressure": 1021.51,
                "pressureTrend": "rising",
                "temperature": 18.54,
                "temperatureApparent": 18.71,
                "temperatureDewPoint": 14.98,
                "uvIndex": 0,
                "visibility": 26766.45,
                "windDirection": 293,
                "windGust": 15.74,
                "windSpeed": 9.17
                "forecastStart": "2023-01-09T01:00:00Z",
                "cloudCover": 0.22,
                "daylight": false,
                "humidity": 0.83,
                "pressure": 1021.88,
                "temperature": 17.96,
                "temperatureApparent": 18.13,
                "temperatureDewPoint": 14.99,
                "uvIndex": 0,
                "visibility": 26161.74,
                "windDirection": 305,
                "windGust": 15.92,
                "windSpeed": 9.25
                "forecastStart": "2023-01-09T02:00:00Z",
                "cloudCover": 0.21,
                "daylight": false,
                "humidity": 0.84,
                "pressure": 1022.19,
                "temperature": 17.67,
                "temperatureApparent": 17.84,
                "temperatureDewPoint": 14.97,
                "uvIndex": 0,
                "visibility": 25872.19,
                "windDirection": 318,
                "windGust": 18.25,
                "windSpeed": 10.18
                "forecastStart": "2023-01-09T03:00:00Z",
                "cloudCover": 0.15,
                "daylight": false,
                "humidity": 0.86,
                "pressure": 1022.18,
                "temperature": 17.12,
                "temperatureApparent": 17.26,
                "temperatureDewPoint": 14.82,
                "uvIndex": 0,
                "visibility": 25193.45,
                "windDirection": 327,
                "windGust": 15.57,
                "windSpeed": 8.93
                "forecastStart": "2023-01-09T04:00:00Z",
                "cloudCover": 0.28,
                "daylight": false,
                "humidity": 0.88,
                "pressure": 1021.78,
                "temperature": 16.46,
                "temperatureApparent": 16.53,
                "temperatureDewPoint": 14.45,
                "uvIndex": 0,
                "visibility": 23565.73,
                "windDirection": 350,
                "windGust": 10.32,
                "windSpeed": 7.62
                "forecastStart": "2023-01-09T05:00:00Z",
                "cloudCover": 0.42,
                "conditionCode": "PartlyCloudy",
                "daylight": false,
                "humidity": 0.90,
                "pressure": 1021.02,
                "temperature": 15.89,
                "temperatureApparent": 15.93,
                "temperatureDewPoint": 14.27,
                "uvIndex": 0,
                "visibility": 23171.24,
                "windDirection": 15,
                "windGust": 11.80,
                "windSpeed": 7.39
                "forecastStart": "2023-01-09T06:00:00Z",
                "cloudCover": 0.53,
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1020.46,
                "temperature": 15.47,
                "temperatureApparent": 15.49,
                "temperatureDewPoint": 14.08,
                "uvIndex": 0,
                "visibility": 19733.18,
                "windDirection": 36,
                "windGust": 8.72,
                "windSpeed": 5.78
                "forecastStart": "2023-01-09T07:00:00Z",
                "cloudCover": 0.65,
                "conditionCode": "MostlyCloudy",
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1020.20,
                "temperature": 15.26,
                "temperatureApparent": 15.24,
                "temperatureDewPoint": 13.87,
                "uvIndex": 0,
                "visibility": 14766.60,
                "windDirection": 41,
                "windGust": 6.07,
                "windSpeed": 4.63
                "forecastStart": "2023-01-09T08:00:00Z",
                "cloudCover": 0.37,
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1020.13,
                "temperature": 14.80,
                "temperatureApparent": 14.70,
                "temperatureDewPoint": 13.33,
                "uvIndex": 0,
                "visibility": 14261.56,
                "windDirection": 21,
                "windGust": 6.19,
                "windSpeed": 3.91
                "forecastStart": "2023-01-09T09:00:00Z",
                "cloudCover": 0.22,
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1019.95,
                "temperature": 14.32,
                "temperatureApparent": 14.17,
                "temperatureDewPoint": 12.95,
                "uvIndex": 0,
                "visibility": 13205.45,
                "windDirection": 53,
                "windGust": 5.22,
                "windSpeed": 3.16
                "forecastStart": "2023-01-09T10:00:00Z",
                "cloudCover": 0.25,
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1019.70,
                "temperature": 14.15,
                "temperatureApparent": 13.98,
                "temperatureDewPoint": 12.74,
                "uvIndex": 0,
                "visibility": 11965.90,
                "windDirection": 77,
                "windGust": 5.53,
                "windSpeed": 3.17
                "forecastStart": "2023-01-09T11:00:00Z",
                "cloudCover": 0.29,
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1019.98,
                "temperature": 13.73,
                "temperatureApparent": 13.51,
                "temperatureDewPoint": 12.36,
                "uvIndex": 0,
                "visibility": 10845.17,
                "windDirection": 76,
                "windGust": 5.91,
                "windSpeed": 3.86
                "forecastStart": "2023-01-09T12:00:00Z",
                "cloudCover": 0.36,
                "daylight": false,
                "humidity": 0.91,
                "pressure": 1020.36,
                "temperature": 13.57,
                "temperatureApparent": 13.32,
                "temperatureDewPoint": 12.14,
                "uvIndex": 0,
                "visibility": 10843.71,
                "windDirection": 86,
                "windGust": 5.45,
                "windSpeed": 3.63
                "forecastStart": "2023-01-09T13:00:00Z",
                "cloudCover": 0.40,
                "daylight": true,
                "humidity": 0.90,
                "pressure": 1021.01,
                "temperature": 14.18,
                "temperatureApparent": 13.99,
                "temperatureDewPoint": 12.61,
                "uvIndex": 0,
                "visibility": 11579.93,
                "windDirection": 88,
                "windGust": 5.66,
                "windSpeed": 3.24
                "forecastStart": "2023-01-09T14:00:00Z",
                "cloudCover": 0.44,
                "daylight": true,
                "humidity": 0.88,
                "pressure": 1021.61,
                "temperature": 15.50,
                "temperatureApparent": 15.43,
                "temperatureDewPoint": 13.52,
                "uvIndex": 1,
                "visibility": 12073.81,
                "windDirection": 70,
                "windGust": 6.53,
                "windSpeed": 2.70
                "forecastStart": "2023-01-09T15:00:00Z",
                "cloudCover": 0.32,
                "daylight": true,
                "humidity": 0.81,
                "pressure": 1021.98,
                "temperature": 17.92,
                "temperatureApparent": 18.02,
                "temperatureDewPoint": 14.58,
                "uvIndex": 2,
                "visibility": 19371.16,
                "windDirection": 54,
                "windGust": 7.96,
                "windSpeed": 3.17
                "forecastStart": "2023-01-09T16:00:00Z",
                "cloudCover": 0.29,
                "daylight": true,
                "humidity": 0.74,
                "pressure": 1021.80,
                "temperature": 19.84,
                "temperatureApparent": 20.03,
                "temperatureDewPoint": 15.04,
                "uvIndex": 4,
                "visibility": 16931.38,
                "windDirection": 335,
                "windGust": 10.33,
                "windSpeed": 4.30
                "forecastStart": "2023-01-09T17:00:00Z",
                "cloudCover": 0.23,
                "daylight": true,
                "humidity": 0.70,
                "pressure": 1020.98,
                "temperature": 21.18,
                "temperatureApparent": 21.50,
                "temperatureDewPoint": 15.55,
                "uvIndex": 5,
                "visibility": 20483.94,
                "windDirection": 320,
                "windGust": 13.64,
                "windSpeed": 7.63
                "forecastStart": "2023-01-09T18:00:00Z",
                "cloudCover": 0.19,
                "daylight": true,
                "humidity": 0.68,
                "pressure": 1019.97,
                "temperature": 21.95,
                "temperatureApparent": 22.32,
                "temperatureDewPoint": 15.75,
                "uvIndex": 5,
                "visibility": 18323.52,
                "windDirection": 319,
                "windGust": 15.20,
                "windSpeed": 9.65
I’m using the JSON API data source
Welcome baxk as smith288 :wink:
Anyways, you want the utc time in from api to local time.
Which visualization will you be using?
Sorry about that. I logged in through GitHub on one and didn’t on my phone on the other. Haha
Im using a time series graph.
If you want to get the local time I would go with apache echart plugin
Not sure if this is right, but do I make the appropriate offset in the map of the series like such?
data: sData.map((d, i) => [new Date(sTime[i]).setHours(new Date(sTime[i]).getHours() - 5), d.toFixed(2)]),
That could be problematic if dayvlight savings time is a thing in your area
Also check this out
So I think i figured it out. I actually just needed to update the datasource params to include a “hourlyStart” reference and use the ${__from:date}. The issue with Apple’s Weatherkit is regardless of the timezone I pass in, they will default to return data from 00:00:00Z instead of the time i requested based on the timezone (America/New_York). So I pass in hourlyStart param with grafana’s dashboard variable and it updates the api call to start at the time grafana has for the data request. Thanks so much for helping.
