Hi all, does anybody know how to not only show the weather forecast for the next few days but also the last 3 days in order to show the relation between weather and pv producation? It would be great to be able to see a span of about 6 days, 3 showing the past and 3 forecasting the future… Thanks a lot, Manu
What is your datasource
meteblue iframe, does that help? I’m new at grafana, so not quite sure which information you really need…
So it’s embedded stuff not a grafana dashboard with datasource?
it’s embedded in a grafana dashboard (iframe)
Then it’s not a grafana issue unless it is being fed data from grafana
ah, you’re right… I probably need to find some weather chart that is able to also show past data… thanks for your quick support
also look at other possibilities without embedding.
