Looking for a way to have my alerts end up in syslog on the local machine. We have LOTS of corporate tools that monitor syslog for events and create incidents and the like. Is there a reliable way to have a contact point go to syslog. I enabled 514 tcp and can use a web hook to get it into syslog, but grafana does not get a response back to keeps generating the message at the repeat interval. Anyone know of a webhook receiver to syslog app?
Thanks
From your message, it sounds like you’re correctly sending alerts using the webhook contact point.
“, but grafana does not get a response back to keeps generating the message at the repeat interval. Anyone know of a webhook receiver to syslog app?”
Are you encountering a limitation of the webhook integration, or are you trying to control the repeat notification behavior?
If it’s the latter, you can adjust the repeat interval
option in the notification policy that handles these alerts. This option defines how often the notification is repeated if the alert status did not change.
