Would it be possible in Grafana to alert to local installed syslog service ?
May be you have configured in the syslog.conf file :
local5.* /var/log/alerts.log
Now I want to send alerts when the threshold exceeds to the local syslog service with
Facility = local5 and Severity = Error.
How would it be possible ?
If you go to alert notification channels and create a new channel you can see the available notification channels (slack, email, pagerduty, webhook, etc), syslog is not currently available as an notification channel type
Yes I already seen these types,
but may be there is a way via a gateway to convert from a “Grafana supported notification” to syslog ?
May be - yes
I think about how I can translate a webhook message to a syslog message.
