8.5.11 on Docker -
Users with role Viewer have the dashboard settings button. Our users can make changes to the dashboards but can’t save them, they can extract the dashboard JSON and deploy it to Grafava.
The button is no longer available, but if a user add the query string editview=settings to the dashboard URL it as access to it -
Using the button “Settings” on the top right of the dashboard -
What happened?
the button was available on version 8.4.11 -
Probably a configuration that I’m missing or it was a change -
{ “name”: “GF_SERVER_HTTP_PORT”, “value”: “80” },
{ “name”: “GF_SERVER_DOMAIN”, “value”: “dashboards.XXXXX.net” },
{ “name”: “GF_SERVER_ROOT_URL”, “value”: “https://dashboards.XXXXXX.net” },
{ “name”: “GF_SERVER_ROUTER_LOGGING”, “value”: “true” },{ "name": "GF_DATABASE_TYPE", "value": "mysql" }, { "name": "GF_DATABASE_HOST", "value": "rds_host:3306" }, { "name": "GF_DATABASE_NAME", "value": "rds_db" }, { "name": "GF_DATABASE_USER", "value": "rds_user" }, { "name": "GF_USERS_ALLOW_SIGN_UP", "value": "false" }, { "name": "GF_USERS_ALLOW_ORG_CREATE", "value": "false" }, { "name": "GF_USERS_AUTO_ASSIGN_ORG", "value": "true" }, { "name": "GF_USERS_DEFAUT_THEME", "value": "dark" }, { "name": "GF_USERS_VIEWERS_CAN_EDIT", "value": "true" }, { "name": "GF_AUTH_DISABLE_LOGIN_FORM", "value": "true" }, { "name": "GF_AUTH_ANONYMOUS_ENABLED", "value": "true" }, { "name": "GF_AUTH_ANONYMOUS_ORG_NAME", "value": "XXXXX" }, { "name": "GF_AUTH_ANONYMOUS_ORG_ROLE", "value": "Viewer" }, { "name": "GF_AUTH_GENERIC_OAUTH_ENABLED", "value": "true" }, { "name": "GF_AUTH_GENERIC_OAUTH_NAME", "value": "XXXX Authentication" }, { "name": "GF_AUTH_GENERIC_OAUTH_ALLOW_SIGN_UP", "value": "true" }, { "name": "GF_AUTH_GENERIC_OAUTH_CLIENT_ID", "value": "XXXXX" }, { "name": "GF_AUTH_GENERIC_OAUTH_CLIENT_SECRET", "value": "XXXXXXX" }, { "name": "GF_AUTH_GENERIC_OAUTH_SCOPES", "value": "email" }, { "name": "GF_AUTH_GENERIC_OAUTH_AUTH_URL", "value": "https://XXXX/oauth2/auth" }, { "name": "GF_AUTH_GENERIC_OAUTH_TOKEN_URL", "value": "https://XXXX/oauth2/token" }, { "name": "GF_AUTH_GENERIC_OAUTH_API_URL", "value": "https://XXXX/userinfo" }, { "name": "GF_UNIFIED_ALERTING_ENABLED", "value": "false" }, { "name": "GF_ALERTING_ENABLED", "value": "true" }, { "name": "GF_METRICS_INTERVAL_SECONDS", "value": "20" }, { "name": "GF_INSTALL_PLUGINS", "value": "grafana-clock-panel,grafana-piechart-panel,cloudflare-app,briangann-gauge-panel,jdbranham-diagram-panel,mtanda-histogram-panel,grafana-image-renderer,agenty-flowcharting-panel,grafana-polystat-panel,grafana-opensearch-datasource" }, { "name": "GF_RENDERING_SERVER_URL", "value": "https://XXXXXX/render" }, { "name": "GF_RENDERING_CALLBACK", "value": "https://dashboards.XXXXX.net/" } -
